how many bagged E30`s here ?
  • Acehye559
    • 1033
    #121
    • dillon7
      • Mar 2013
      • 824
      #122
      Originally posted by blue plates
      How hard is it to tuck wheel in the front?
      Tucking front wheel is actually really hard depending on wheel size. On 16"s I'm laying oil pan, subframe, and the tire is sitting on the inner wheel well and I'm still at least at 1/2" from tucking wheel. The main problem is the wheel well and there isn't much you can do about that. On 17"s I think it might be possible.
      Instagram: @dillonmakar
      Build thread HERE
      • NickL
        • 562
        #123
        Tucking 17's is possible with a small tire and the pinch welds ground flat I THINK. Ive only ever ran 16's and my car lays the subframe on the ground before it will tuck them.
        1987 325is - S52
        • blue plates
          • Feb 2014
          • 580
          #124
          That was my understanding as well, I was hoping 16s could be tucked. If it ends up being impossible I may run 15s and call it a day.
          Originally posted by IRON-E
          Yeah, you're definitely a vw
          • NickL
            • 562
            #125
            It'll be even harder to tuck 15's. If you want the wheel to fill up the arch better, go with 16's or 17's.
            1987 325is - S52
            • blue plates
              • Feb 2014
              • 580
              #126
              Haha yea I thought that was pretty apparent if I couldn't tuck 16s. I couldn't tuck 15s.
              • E30SPDFRK
                • 5714
                #127
                With a 215/40 and flattened pinch welds you can get a 16 even with the fender, but not tucking. You would need either tubbed wheel wells and slightly taller tires or shorter tires and the entire underside of the car raised in order to tuck.
                Byron
                Leichtbau
                • NickL
                  • 562
                  #128
                  Right, I was just confused as you started out with wanting to tuck wheel and then settled on 15's haha. I gotcha.
                  1987 325is - S52
                  • animal
                    • Jan 2010
                    • 804
                    #129
                    ^^top -jack your car is insane.
                    can you make it to a rude cruise around the bay on Nov 30th?
                    91 DS S52 Slicktop, 91 Calypso M42, 89 Royalblau M20, 84 Bahama Beige 323i, M535, Euro e24, ap1
                    www.RenownUSA.com
                    ig @RenownUSA / @rude.scott
                    • OOMPH!
                      • 3487
                      #130
                      Anyone using the Bag Riders e30 specific kit?
                      • Acehye559
                        • 1033
                        #131
                        If I don't work, I will def make it. Hopefully no unexpected shit like last time.
                        • Shangsta
                          • 1485
                          #132
                          Originally posted by Acehye559
                          Winning. Those integrale sc's? specs
                          :shock:
                          • haggardfab
                            • Sep 2011
                            • 283
                            #133
                            on level ground i tuck a little bit of my wheel in the front and a whole lot in the back.. im laying pinch weld in the front and the tire hits the top of the inner fender
                            IG: haggardfab
                            • dillon7
                              • Mar 2013
                              • 824
                              #134
                              Old pic from SOWO
                              BMW on bridge (1 of 1) by Dillon Makar, on Flickr
                              Build thread HERE
                              • Acehye559
                                • 1033
                                #135
                                Their ccw d11l's, 16x9 n 16x10
